sony a57 blurs perfectly clear shots in "m" mode
mil34
Hey everybody!
So this is the problem. It only happens in manual mode. I take the shot - and it's perfectly clear on the display. It shows up on the display post-shot - and it's clear... and then it starts to blur out. What is causing this? Is this some mode or effect i'm not aware of? If so, tell me how to get rid of it..
P.S. This is not a too long exposure issue..
Guest Peter Kelly
It certainly sounds like an effect of the 'Potrait' mode, though I wouldn't be able to describe it as I don't use them myself.
I do know it blurs the background though. Perhaps it blurs everything it calculates is not a figure, which would be the whole scene for a landscape shot, for example.
No suggestion above addresses the peculiarity of this
happening only in manual mode. That is tooooo weird.
It sounds like just maybe a problem with the monitor,
but I cannot image why it's linked to the use of the
manual mode. Anywho, first eliminate the monitor as
a variable and review your shots only in the viewfinder.
Also, review your shots on your PC, direct from the
card, eliminating the camera if both the monitor and
the viewfinder exhibit this weird behavior.
Very often, unexplainable behavior is user error but
again, this is difficult at a distance/online due to the
multiplicity of settings/features/modes/etc
I still cannot accomodate how this is linked to use of
the manual mode only. But OTOH you provide very
little info and there are soooo many variables, and
we are not in the same room with the device. Not to
blame you for the minimal info, as the variables are
quite vast. There's a feature somewhere in the menus
called [iIRC] "Initialize". It will reset ALL user settings
back to factory defaults. If you're OK with undoing all
customizing you may have set on the camera, this is a
sure way to eliminate user error in how you've adjusted
and set up the camera. If you bought a used camera
then initializing it is usually necessary.
example.
IIRC Portrait mode overrules Manual mode.
Just a random idea:
Reset the auto-review time to a much longer
duration. Also reset it to no auto-review time
at all, so you hafta press the playback button
to get a review. The results of this testing
may, or may not, lead toward a solution.
I don't recognise this problem, although I don't have the a57.
What are your basic image settings in the camera and how do the images look when you import them on you computer?
