Sony Alpha 7S II scan line issue
CJT3
Hi all, was testing out my new Alpha 7s II and I noticed I was getting these weird sort of scan lines while recording. My initial thought is it might be the light source, which is a Hue LED light bulb, hopefully I didn't receive a dud camera.
Here's a link to some test footage with the problem:
I would say that is typical of LED lights. I have them in my kitchen and also had this issue at Christmas with the LED lights on the tree which looked as if they were flickering on and off. I found if I lowered my shutter speed to 1/80 or below, the lines/flicker disappeared.
Experiment. Not a duff camera in my opinion.
Likewise I keep my LED lit interior shooting
down to 1/30 if possible. When I hafta shoot
some stills at 1/50 +/-, due to motion/action, I'll
use high speed continuous shooting. 1/50 thru
1/80 are borderline risky. Most frames will be
problem free, but not every frame. Thus I get
"insurance frames" with high speed continuous.
At 1/30 [60 cycle AC] you don't need insurance
frames, but it can be too slow for action. Any
speed above 1/80 is really risky for my A72. If
you have a different A7 version, your shutter
blades may travel a bit faster but the useable/
safe shutter speeds won't be hugely faster.
I spoze the video scan lines will vary somewhat
depending on your chosen frame rate, but don't
blame the camera. It's definitely the household
LEDs. Studio grade LED lighting uses a more
sophisticated AC-DC power conversion.
