Sound Recording
Michael_j
  • 2 months later...
Adequate is in the ear of the beholder.
For those whose ears do require an external mic, I can
recommend the Zoom H1 handheld PCM digital audio
recorder. It's small, as small as many mics that do not
record audio. It's stereo, runs on 1 AA cell, and unlike
a mic, it has user control for its input and output levels.
Input is by its own built-in mics which are excellent and
set to an X-Y pattern. Output is the typical 3.5mm TRS.
Soon as it's powered up it's already in Record Standby
mode and you can use the tiny stereo meter in its LCD
panel to set the input [do a sound check]. Then set the
output level to whatever makes your camera happy,
guided by the audio level readouts on your camera's
rear monitor [LCD panel]. To use it as a mic, without
recording, just let it remain in standby. Standby does
NOT time out. It will stay in standby forever, waiting for
you to hit the Record button, but it serves as a mic just
running standby mode.
This unit has a 1/4-20 thread socket for fixing it to any
tripod or bracket. I use a bracket to the camera, and a
piece of weather stripping foam over the 1/4-20 screw
for isolation against camera handling noise.
Acoarst the cool thing is that your mic can also record
a continuous audio track to back up whatever audio is
being recorded with the video. You can start and stop
the camera, which starts-stops the camera audio, but
the back up track is continuous. The H1 can run for
several hours on one AA cell.
