LA-E2 for Full Frame [not LA-E4]
Golem
The APSC adapter, LA-E2, comes really close
to doing the job of an LA-E4 .... so if you have
one hanging around, a left-over of your switch
to full frame, if you haven't tried using it, you
should check it out.
Of my collection of Maxxum lenses, results vary
as to how much image is lost at the margins, but
it's far less than I had expected before giving it
a try. Of about about a dozen lenses, most are
in the 1.125X crop factor catagory. Just a few
have a 1.2X crop factor. Not too shabby !
HERE'S the COOOL part ....
No math or measurements needed to know the
crop factor. Instead of the APSC crop feature
[which I disabled], I use the Clear Image digital
zoom to eliminate the dark corners. I just read
the crop factor right from the digital zoom scale.
The scale only reads in whole tenths, 1.1X, 1.2X
etc but there are 3 possible "1.1X" positions and
2 possible "1.2X" positions. The EXIF data tells
the exact crop, so thaz how I know that many of
my lenses only need 1.125X. EXIF reads to the
3rd decimal place :-)
The COOOOL part CONTINUES ....
The digital zoom does not reduce the pixel count.
Images are still 4000x6000 pixels. Digital zoom
extrapolates and replaces the "lost" pixels. The
resolution is not what you'd get from 24MP. It's
what you get from about 19 to 20MP. But at least
the pixelation of large prints isn't any worse than
any 24MP camera .... for the A7M2, but whatever
camera you use, the effect applies proportionally.
BTW the degree of crop varies from lens to lens,
but there is no pattern to that as related to focal
length. My widest lens has the very smallest black
corners. The black corners on my 70-210 grow a
bit as it is zoomed to longer FLs.
Here's the 70-210 at 70mm, with a 1.125X digital
zoom crop:
