A7ll & commlite ef to e mount adapter.....not working!!!! Help needed
    • Thanks! The 18-105 mm /f4 was PERFECT lens for my needs but a HUGE disappointed. I bought it with the camera, then I brought it with me on a trip. To my disappointed, all pictures came out slightly blurred, like the lens was slightly out of focus. Stepping down was not solving the issue. The kit lens was definitely better, to my surprise. Thinking that I got a lemon, I went back to the shop where I bought It (luckily, I has bought both the camera and the lens in a brick and mortar store). We tested the lens on another camera and it was the same. Then we tested other copies of the same lens that the store had in stock and all showed the same lack if sharpness. All pictures slightly out of focus. In the end I returned the lens and used the money to buy other equipment. I must admit that it was a perfect lens for video but it is not what I use my camera for. Actually this was confirmed by the shop owner, most buyers of the 18-105 mm are interested in its video capabilities. I will have a look at the Tamron, the Sony 16-55 is almost double the price, at least here, so I will keep it out of the picture, at least for the time being. The Sigma also looks as an interesting option.
    • Hello ! A friend gave me an old Sony SLT A65 that was locked in a suitcase for some years and guess what... It was pretty dirty. The translucent mirror looks strange. I know it's a pellicle mirror, but something is really weird , at least to me who never saw this entity before. It shows a rainbow pattern when lit, like a diffraction grid. And when I point the camera to a strong light source, let´s say streets lights or car lights, a huge halo and a diffuse pattern appears, almost like one of that photographic filters from the '70s. I guess the mirror is damaged. Does enyone have any experience with this ? I managed to remove the mirror and carefully rinse it with water and detergent solution , rinse again and dry, but the rainbow patter persists. My question is basically about the translucent mirror behavior with strong highlights and if the rainbow pattern on its surface is normal.   Thanks!
    • Sounds like you need a manual, and you are correct different settings can affect what you can do in the drive more.  Did you simple press the DRIVE button and select the THREE rectangles? There are several "burst" modes -- that you set with the Fn button or DRIVE button.  One takes several photos, when you press the button once (CONTINUOUS).  Another requires you to press the shutter button each time (SINGLE).  When you press the DRIVE button, what icon shows up -- a single rectangle or three?
