WHY A-MOUNT WILL GO ON
It's not that the lenses will stop working. They can be set to manual focus and live on for many many years.
It's the camera bodies that have the real life cycle. If Sony stops producing new and more advanced A mount bodies, the need for A mount lenses will just dry up.
Sony can continue to produce A mount lenses, but if there are no bodies to use them natively, what is the point?
