Best settings A7RII - first attempt
Muizen
Yesterday I received my A7RII with Zeiss Batis 25.
Coming from an RX1 I am somewhat familiar with its settings, but it is far more complicated than I thought it would be.
That is partly due to the rather primitive Sony user manual.
 I hope that I will get some help via this Forum!
I have introduced the settings to separate AF from the shutter button:
AEL Button: AF/ON
AF/MF Button: AF/MF ctrl Toggle
AF w/Shutter OFF
When I move the lever (right of top LCD) up to AF/MF this will enable the selection of either AF or MF.
When thereafter this lever is moved down to AEL-position can AF or MF be used, whereby in position AF pressing the small center button will result in AF.
My question is, what is the purpose of the "large central button", if used, switching AEL on and off?
For what purpose is this?
I have no idea why this suddenly has become an AEL button that can be switched off and on?
Is this necessary and can I not use this central button for some more useful purpose?
Thanks for reply!
Harry
I am a newbie to this camera, only had it a week so I have taken to u tube to learn this camera, I had the a7-a72, so i have a little bit of nowhow but not much.
there is a guy on utube who is great on a7 cameras and has a 4hour vid on the a7r2. look for gary fong, I have registerd with his site ( gary fong.com)
and lean from them. there are others as well but I like this one. with utube you can't go wrong
on my a7 [you have one more custom button than me] i have the following, bear in mind i use some legacy glass in manual focus mode hence some of the settings.
don't know if this will help
menu_gearwheel_6_custom key settings
control wheel not set
ael button ael toggle
af/mf button af/mf control hold
custom button 1 focus magnifier
custom button 2 iso
custom button 3 focus settings
movie button movie only
dial/wheel lock lock
menu 2
centre button af on
left drive
right white bal
down peaking colour
hope that helps
In many countries the manual that comes with the camera
is an abridged one. You have to go to the site and download
the full manual........
Certainly true about my N. American version A7M2. The full
manual is a PDF, much easier to use than a paper version,
due to the bookmark feature of PDF.
For new noobs, I also recommend a 3rd party bible from your
fave bookseller. There's usually 3 or 4 to choose among.
Certainly true about my N. American version A7M2. The fullmanual is a PDF, much easier to use than a paper version,due to the bookmark feature of PDF.For new noobs, I also recommend a 3rd party bible from yourfave bookseller. There's usually 3 or 4 to choose among.`
Do you have titles of good books about the A7RII?
Thanks!
Harry
