Sony A7II + Tamron 15-30 SP 2.8
drasko2015
A friend borrowed me his Nikon Mount Tamron 15-30 ultra wide lens, ive tried it for some shots on my A7II:
  • 10 months later...
Just curious did you find that the corners were softer when using the adapter with the Tamron 15-30, I was thinking about purchasing this lens but after looking at a few reviews I was wondering if that would be an issue ?
If the flanges on the adapter are in parallel planes,
no such problem. Any ultra-wide lens is extremely
vulnerable to a failure of parallelism, so you need
a good adapter.
Lack of parallelism results in different areas of the
frame being focused to different distances. Some
will experience this as "soft" corners, and stopping
down does relieve this rather well. But the corners
are not actually soft. The are just sharply focused
at slightly different distances. A scene with depth
will often hide this. OTOH is could exacerbate it.
Get a quality adapter. 3-figgers USD for a simple
"dumb" one, plus extra $$  for full connectivity and
all the headaches that might bring :-(
I borrowed a friend's $25 Fotasi adapter and it was
parallel, but for that price there may be sample to
sample variation. Also the rear flange and the latch
were not my idea of quality. So I got a MetaBones,
which also tested parallel, altho a tiny bit short of
exact length ... waaaaay better than too long, cuz
you can ignore that, or shim it. [i shimmed it.]
