Milky Way | Petaluma, CA | Sony A7S | Samyang 12mm
bryangoff
Some pictures I took tonight. I used my A7S with my Samyang 12mm. Came out pretty good I think.
20 sec
ISO 1600
f2
Same settings as the first.
Same settings as the first one.
My greatest selfie ever! Same settings as the first one. This is also what your image will look like if you do not crop it.
