a7II Manual Focus question:
If I mount a third party manual focus lens on the camera, and in manual focus mode, is there a way to bring up the magnification window to aid focus?
Yes :)
You can assign a button and you will have two zoom options or just leave the default button where it is so the one near the  viewfinder - very comfortable.
I am using my a7II with Contax Zeiss (got it just a week ago) and it works like a charm am not as fast as AF now but will get there. I like the focus peaking too but with 1.4 aperture is hard to nail it just by using it.
That image is 1.4 focused by zooming in.
