Sony Alpha A7R
Want to sell brand new Sony Alpha A7R with Complete accessories,1year warranty,
what includes in the box.
Very affordable Price.
AC-UB10 AC Adapter
Shoulder Strap
Body Cap
Hot Shoe Cover
Eyepiece Cup
Micro USB Cable
PlayMemories Home App
Image Data Converter Version 4 Software
Limited 1-year Warranty
For more details about the camera and pictures do contact me via Email :
tmelect001@gmail.com..  Skype : tmelect001
